Problems importing into Adobe CS6 from PMW 200
Joan Bewley
on Jul 16, 2013 at 3:36:11 pm
Hi
I have recently got a PMW 200 and is new to the digital file having used dv tapes in the past. I have been shooting in HD but my problems is importing into adobe CS6, an error message says there are no video or audio stream. Help
Kind regards
Jo
Ian Cook
Re: Problems importing into Adobe CS6 from PMW 200
on Jul 16, 2013 at 4:22:16 pm
What file are you importing? Are you working in HD422 or in EX mode?
In HD422/UDF mode you import the .mxf and in EX/Fat mode you import the .mp4. It's also not recommended that you import the files using File-->Import. If you use the embedded media Browser you can set it to the file based format you are importing (for example, 'XDCAM HD' or 'XDCAM EX'), click on the card or card archive and access the files from there without having to drill down into the folder structure.
