PMW500 version UP No phase 3/final VF info ?
COW Forums : Sony Cameras
Robin Probyn
on Jun 14, 2013 at 5:29:48 am
Hi
Just now did the version up for my camera .. 1.4 Sony PMW500.. phase one info came up in the VF .. phase two no info as the manual says.. but then no phase 3 VF info or final "update ok" .. just the tally light went from solid to flashing.. although the timing was about right..
Switched off and then on.. seemed fine.. in menu its says version 1.4.. the auto white now has pure option.. records and plays back fine.. I had this happen last time and thought I had a problem and took in to be done..
So question being.. is this standard procedure for the 500 updates.. are the "how to" PDF,s a bit out of date.. ? Does my camera have a fault..
