Sony EX1 external monitoring issues
joseph wilkins
on Jun 8, 2013 at 2:57:21 am
So I have a Sony EX1.
About 2 years ago, the Component out quit giving me a color signal.
All I can get out of it - regardless of the monitor I plug into is a black and white signal.
It's very annoying as it is a studio camera and my clients like to watch in video village.
So I figured I'd go buy a cable to plug into the HDSDI out port and plug in that way.
I attached to my same IKAN 7" monitor that worked fine ( apart from the B&W)... but no image.
I flipped iLink off and enabled HD and all the steps the manual says to do... nothing. I switched the monitor through the various inputs... nothing.
I took the EX1 down to my local camera dealer and he plugged it into a monitor... perfect picture immediately without messing with any of the settings.
So I know the camera is set to output a picture... any idea why my monitor will not display it?
We even tested with the cable and it worked at the store... so it must be the monitor.
I think it's a 720p monitor... not 1080p... but I get a signal in component mode...
Any help would be greatly received.
Jw van der Vlies
Re: Sony EX1 external monitoring issues
on Jun 9, 2013 at 10:41:18 am
Maybe the Y component input can be set on composite also? So that it only 'sees' the Y channel, which is black and white.
joseph wilkins
on Jun 9, 2013 at 2:29:18 pm
Thanks very much.... but I am a dummy... can you please put that into simple terms I can understand and tell me how I can fix it? Thanks so much
Jw van der Vlies
on Jun 9, 2013 at 2:41:11 pm
please give me a link of your monitor, there are more ikan 7 inch
joseph wilkins
on Jun 9, 2013 at 2:43:51 pm
Ikan V8000 HDMI.
Thanks again
Jw van der Vlies
on Jun 9, 2013 at 2:48:05 pm
component and composite are different connections so my theory doesn't match..
I'm afraid I can help you. It's a long shot, but maybe you've set the color saturation to zero or something? which means that all the colour is gone
joseph wilkins
on Jun 9, 2013 at 2:54:00 pm
it is the same on another monitor... it's not a monitor issue... its in-camera.
Any ideas on why the Ikan is not displaying the HDSDI out? Does a monitor need to be 1080p to display that? I think my Ikan is only 720p
Jw van der Vlies
on Jun 9, 2013 at 3:03:01 pm
your monitor, as i see, does not have hdsdi input.
your original thread mentions that it's the monitor!
out of ideas so far. sorry
joseph wilkins
on Jun 9, 2013 at 3:19:47 pm
OH.. maybe thats the problem ;)
I see a B&C connector... is that not a HDSDI port?
Michael Palmer
on Jun 9, 2013 at 3:18:55 pm
It seems like you need to convert the HDSDI to HDMI for your monitor, these are both digital signals unlike the component/composite ports.
http://www.atvresearch.com/HAWK-SDI-HDMI.aspx
Good Luck
Michael Palmer
Jw van der Vlies
on Jun 10, 2013 at 11:42:23 am
On the camera, the bnc is a hdsdi, on your monitor, i don't think so.
M Palmers advice is a good option.
