Fujinon S17X6.6BRM on a Sony EX3 - Not fitting on ACM-18 mount
COW Forums : Sony Cameras
Brian Harris
on May 7, 2013 at 7:40:05 pm
Just bought a Fujinon S17X6.6BRM SD lens to use on my Sony EX3 for some live event work. I was under the impression that it would work with ACM-18 lens adapter, since it is a standard 1/2" ENG lens but it doesn't quite fit. I can get it mounted with some fiddling but the lens mount is obviously a little small for the ACM-18 mount. I've tried looking for a different adapter but I haven't had any luck and I'm feeling stumped right now. Anyone have any ideas? Did I jump the gun and get a completely incompatible lens? Thanks in advance!
Damian Viera
Re: Fujinon S17X6.6BRM on a Sony EX3 - Not fitting on ACM-18 mount
on May 19, 2014 at 9:46:31 pm
Maybe it's too late for your lens problem. The first link shows a table of the links compatibles.
http://www.fujinonbroadcast.com/pdf/SonyXDCamBrochure.pdf
Here you can obtain the camera-lens.pdf file
http://www.umlib.com/brand/Panasonic/category/Camcorders/model/AG-DP800
"brand:Panasonic
category:Camcorders
file name:camera-lens.pdf
pages:11"
Greetings from Spain
Carlos
