Anyone have experince with the Sony BRC -H 700 Post Workflow
COW Forums : Sony Cameras
Mark Dershowitz
on Mar 14, 2013 at 5:57:01 pm
Has anyone work with this camera and post workflow. Final cut dosen't see the CF Cards in Log and and Transfer, Avid will AMA but wont group all clips together. Is there a Plugin or AMA Plugin out there. Thanks
Ian Cook
Re: Anyone have experince with the Sony BRC -H 700 Post Workflow
on Mar 14, 2013 at 6:28:44 pm
Are you sure it's a BRC-H700? That's a pan/tilt robotic camera..
Log and Transfer/AMA require the card's directories to be intact-- make sure nothing in the AVCHD folder or below has been renamed or modified.
Media Composer 5 and up can also do manual File-->Import of .mts files but Avid will force a transcode to DNX during import.
