PDW-U1 will not format
COW Forums : Sony Cameras
Brian Young
on Mar 8, 2013 at 10:48:14 pm
Greetings All,
My U1 works fine for burning material from the nanoFlash to 23 or 50gb discs, but i get an error code (0xA100001A) when attempting to format a disc via xdcam drive utility.
Thoughts?
It's not really pressing, as everything seems to be good, but I'm more curious than anything....
Best,
Brian
Brian Young
Los Angeles
http://www.FlacaProductions.com
Ian Cook
Re: PDW-U1 will not format
on Mar 11, 2013 at 1:15:58 pm
what version? make sure you are running the correct driver version and that there are no pending firmware updates (check this in the Utility after verifying/installing any updates)
http://www.sonycreativesoftware.com/xdcamdrive
Brian Young
on Mar 11, 2013 at 5:44:21 pm
Apologies Ian and thanks for your help. I thought I was up to date on drivers/firmware, but an update to firmware 2.54 and driver 4.0.1 did the trick - thank you!
Brian Young
Los Angeles
