Is live stream from PMW-200 into MacBook Pro via. FireWire possible?
COW Forums : Sony Cameras
Evan Howell
on Feb 26, 2013 at 3:38:17 am
Hi, can this be done? I've read a few posts elsewhere that say this is a problem, at least for the EX-1, via HD FireWire. But as far as I know, the two cams are essentially identical. I've also read I need to shoot in FAT. Questions, questions.
Can someone recommend what I need to worry about? Or do? The potential client wants a live stream from my camera into the computer via FireWire for a google 'chat room.' The stream will go for about 3 hours.
Thanks very much in advance.
Ian Cook
Re: Is live stream from PMW-200 into MacBook Pro via. FireWire possible?
on Feb 26, 2013 at 3:26:33 pm
yes, this is possible, just make sure:
-FAT (EX) mode
-record format is a 25 Mbps SP codec
-i.LINK = enabled in OTHERS menu
-i.LINK IO option selected in Video Set-->SDI/HDMI/i.LINK IO Select
Craig Seeman
on Feb 26, 2013 at 4:14:49 pm
Since you don't mention the age of the MBP, if it has Thunderbolt you can use a Blackmagic UltraStudio Mini Recorder and go HD-SDI straight out of the camera. If you do have an older Core2Duo MBP be aware that encoding HDV for a live stream is processor intensive.
Evan Howell
on Mar 3, 2013 at 3:25:36 pm
Thank you for the confirmation!
