wifi with PMW500
COW Forums : Sony Cameras
Robin Probyn
wifi with PMW500
on Jan 14, 2013 at 2:08:06 pm
I buy the wifi adaptor .. plug it in.. then what is the "key" procedure with the 500.. I read its different with the disc 700/800..
Then I can down load ..(something) pilot to my iphone and get a live feed.. is that right or missing something here..
Ian Cook
Re: wifi with PMW500
on Jan 14, 2013 at 2:22:44 pm
You need the CBKUPG01 hardware key to activate the wifi.
You can use the XMPilot tool on iOS devices or Sony Experia phones to stream proxy and perform live logging/metadata entry. You can also do this from a laptop using Content Browser (though you need the Advanced Pack option)..
Robin Probyn
on Jan 14, 2013 at 2:30:19 pm
Ok thanks.. how does that key actually work then.. couldnt find any info on it on line.. is there an idiots guide .. is it a board that goes inside the camera..? what is it.. ?
Thanks again
Ian Cook
on Jan 14, 2013 at 2:36:41 pm
It's a small hardware dongle. It will come with installation instructions.
Robin Probyn
on Jan 14, 2013 at 2:45:45 pm
ok thanks.. and that comes with the wifi set.. or is part of it.. only pictures i can find is the wifi transmitter with USB cable..? and what looks like a holder..
thanks re the proxy file ..
Ian Cook
on Jan 14, 2013 at 2:47:04 pm
again, it's just a dongle, not much to see. it comes separately and mounts internally. the wifi adaptor mounts on the outside near the handle.
Robin Probyn
on Jan 14, 2013 at 3:01:47 pm
Is the mounting internally a job to be done by Sony tech,s.. ? dont know if I want to venture in there with hammer and chisel ..
