No HD SDI output signal on my EX-3's
COW Forums : Sony Cameras
Ed Tworek
on Jan 10, 2013 at 11:21:05 pm
I have 2 1 year old Sony EX-3's. Both do not have an HD SDI output signal. I've run through every configuration in the menu that I can see. I do have a signal through the Monitor Out port. I reset the camera with no change.
Yesterday, we attempted recording via a Ninja and several other devices.
What am I missing?
thanks
Ed
Ed Tworek
Corporate Video Creations
http://www.corpvid.com
Michael Palmer
Re: No HD SDI output signal on my EX-3's
on Jan 10, 2013 at 11:37:43 pm
Select the Highest recording format and make sure the output is campatable with the monitor, I think it's under Genlock for the output and set to 60i
Good Luck
Michael Palmer
Bill Griffin
on Jan 11, 2013 at 12:23:47 am
make sure that the fire wire output is turned off, as if it is "on" it will turn off the HD-SDI port. I think that's the only way the HDSDI will not work.
Bill Griffin
HD Cameraman
972-475-6870
http://www.dallascamguy.com
Dallas, Texas USA
Bill Griffin
on Jan 11, 2013 at 12:51:47 am
so..go to Menu----"others"----go to the bottom, look for "ilink IO" and make sure that its "disabled"..this should fix it.
Bill Griffin
HD Cameraman
972-475-6870
Dallas, Texas USA
