Copying of a clip is not possible
COW Forums : Sony Cameras
Sverker Hahn
on Dec 12, 2012 at 3:46:37 pm
I was copying the whole disk with SuperDuper when a particular file stopped everything:
The same result in XDCam Browser and the Finder.
XDcam Brower show that 16% of the clip is copied before this message stops the action.
I have unlocked the files in the info-window.
Have never experienced this before.
TIA
Sverker
Sverker Hahn, Stockholm
Slower is better!
Sony EX1
Final Cut Studio 2
iMac Intel
MacBook Pro 13"
Ian Cook
Re: Copying of a clip is not possible
on Dec 12, 2012 at 4:19:43 pm
Does the file behave normally when in the camera? I.E. can it be played back from beginning to end?
Sverker Hahn
on Dec 12, 2012 at 5:52:56 pm
Yes, it is played from the harddrive with XDCam Browser from start to end without problems.
Slower is better!
Sony EX1
Final Cut Studio 2
iMac Intel
MacBook Pro 13"
Ian Cook
on Dec 12, 2012 at 5:57:30 pm
can you rewrap into FCP and then re-export a new .mp4?
Sverker Hahn
on Dec 13, 2012 at 10:51:13 pm
Do you mean that the new .mp4 could replace the faulty one inside BPAV?
I´ll give it a try tomorrow.
But how could this thing even be possible? (No, I don´t need to know ...)
Slower is better!
Sony EX1
Final Cut Studio 2
iMac Intel
MacBook Pro 13"
Ian Cook
on Dec 13, 2012 at 11:02:00 pm
no, we're hoping that the re-wrap into FCP succeeds and that we can then export a new file. if this works it will put a loose .mp4 on the root of CLPR. in the OTHERS menu on the camera, select CLIP-->UPDATE to register the new file and create the metadata.
Sverker Hahn
on Jan 1, 2013 at 1:55:03 pm
No, I could not import the whole clip. But it is al long clip - 5 min - and I could use the first third of it. Then I plan to delete the clip and then be able to do a backup of the whole HDD. Just hopin´...
Slower is better!
Sony EX1
Final Cut Studio 2
iMac Intel
MacBook Pro 13"
Ian Cook
on Jan 2, 2013 at 3:49:08 pm
Just checking in to see how it's going? Let me know if we still need to try and figure out a workaround. Been offline for a few days.. Can't tell from the above if the FCP re-wrap worked.
