Video Playback Jumpy in FCP - Sony XDCAM 1080i50
COW Forums : Sony Cameras
Steven Wilson
on Nov 28, 2012 at 7:03:29 am
hi there,
first of all let me tell you my sequence and video details
video footage and sequence settings: XDCAM EX 1080i
when i playback my videos from my SONY EX3 or from Quicktime they look fine.
i have notice the during playback in FCP my video jump/(like pixelate transition).
But if i exported it everything looks normal.
So am guessing is something on the preview. I have attach you a photo to have look at it and tell me your opinion why this problem happens: 5007_screenshot20121128at08.49.00.png.zip
Jim Vlies
Re: Video Playback Jumpy in FCP - Sony XDCAM 1080i50
on Nov 28, 2012 at 2:57:20 pm
First I thought your render was on 'preview' but this looks much more bad. Maybe a codec issue? In the sequence settings?
Does is also happen when you play the clip(s) in the viewer?
Steven Wilson
on Nov 28, 2012 at 3:42:54 pm
in the viewer the clip seems OK. I believe also is a sequence/timeline issue. The sequence has the same settings with the video footage. When i insert them in the timeline FCP does not pop up any format and timeline does not need render either. So this tell me that video footage and sequence are ok.
I have install xdcam codec again but nothing helps.
I have work other projects in the past with the same setup but its the first time happening to me.
Jim Vlies
on Dec 3, 2012 at 9:50:14 am
It looks like your hardware can't buffer it. Too much information for the hardware. It is strange thought. For me this happens when i play a big mp4 h264 in vlc player, but when I play it in quicktime, it's ok.
So I'm only guessing here. It's not THE answer you need, but this is as far as I know. Never had the problem myself.
