OS 10.7.4 and errors with Transfer window
COW Forums : Sony Cameras
anthony Faulkner
on Jul 3, 2012 at 8:53:21 am
I recently got a new mac,
OS 10.7.4
with the transfer window software 2.12
I use the Sony SxS card reader. When I open the transfer window software things are different than they used to be.
1)It won't recognise the BPAV folder only the disk image in finder.
2)It isn't remembering previous files opened.
3) I get this error message when I open the disk image from finder
Failed to compile statement 'select t2.UMID from CLIPMETADATA as t1 outer join MEDIAID as t2 outer join MEDIAINFO as t3 where t1.KEYFRAMECLIPID in ( 6992, 7025, 7014, 7026, 7015, 7004, 7016, 6993, 7005, 6994, 6995, 7027, 7017, 7006, 7018, 7007, 6996, 7008, 6997, 6986, 6998, 6987, 7019, 7020, 7009, 7021, 7010, 6999, 7011, 6988, 7000, 6989, 6990, 7022, 7023, 7012, 7024, 7001, 7013, 7002, 6991, 7003 ) and t1.UMIDID = t2.ID and t1.UMIDID = t3.UMIDID and t3.DISCID = 113;' (1: RIGHT and FULL OUTER JOINs are not currently supported
It works other than that but I am curious as to how to fix things?
HAs anyone else experienced issues with 10.7.4
EDIT***
It will recognise old BPAV folders stored on a server, but when I add them I still get the error message.
Ian Cook
Re: OS 10.7.4 and errors with Transfer window
on Jul 3, 2012 at 1:34:59 pm
2.12 is not supported and doesn't work properly under Lion. You should upgrade to 2.13. You can find it under Applications-->Legacy Applications at http://www.sony.com/xdcam-downloads
