Questions about White Balance
Gavriel Raphael
on Mar 25, 2012 at 7:08:44 pm
Can any ex1 pros share some step by step tips to set the White balance with the EX1 to get the most out of the camera;,
Audio Engineer, music Producer and cunsultant.
Bala Chandran
Re: Questions about White Balance
on Mar 26, 2012 at 12:40:13 am
This is how I do it: Auto iris, point the camera to fill the area with white or neutral grey that receives the light source. Press and hold the white balance button under the lens mount until it finishes processing and gives a kelvin number such as 5600, depending on the light source. Make sure your white balance toggle switch in not on preset.
Jay Levi
on Mar 26, 2012 at 5:21:17 am
from reading around it seems manual WB is better on this camera; unless your power down or use profiles, correct me if i a wrong guys
