Country setting in menu PMW500
COW Forums : Sony Cameras
Robin Probyn
on Mar 23, 2012 at 3:57:08 am
Hi there
I read when the camera is new.. you are given a choice of NTSC/PAL in a Country setting window.. but if you want to change between PAL or NTSC after that.. where is the country setting in the menu.. I have the manual but dont see it there.
Presuming you do have to change the country setting to change between NTSC or PAL format options..
Robin Probyn
Re: Country setting in menu PMW500
on Mar 23, 2012 at 6:49:15 am
found it
