Lion not seeing XDCAM EX drives when camera pugged in
COW Forums : Sony Cameras
Jim Watt
on Mar 16, 2012 at 12:25:02 am
I just installed the latest Sony drivers on a new Macpro running Lion and cannot see the S X S cards/drives on the camera when I plug in the camera to the computer via usb. Also no indication from the camera that it is plugged in like in Snow Leopard.
thx...jw
Ian Cook
Re: Lion not seeing XDCAM EX drives when camera pugged in
on Mar 16, 2012 at 3:18:38 pm
The drivers are not required unless you are using a built-in express card slot. Have you looked in System Profiler or Disk Utility to see if the camera is seen at all? You may also want to check on another machine. Call the tech group @ 800 883 6817 or bis dot product dot support @ am dot sony dot com, they should be able to resolve as long as nothing is broken.
