Sony XDCAM Transfer has stopped me using XDCAM browser!
COW Forums : Sony Cameras
tighe grainger
on Jan 26, 2012 at 4:46:25 pm
I installed XDCAM transfer onto my new mac book pro and since then i cannot use XDCAM browser to import my EX3 rushes into Final Cut Pro. I have also installed Canon XF Utilty, would this be a factor? I have tried and tried but no success. Can you help?
Ian Cook
Re: Sony XDCAM Transfer has stopped me using XDCAM browser!
on Jan 26, 2012 at 5:39:22 pm
The two applications can usually coexist peacefully on the same machine. What exactly is the issue?
tighe grainger
on Jan 27, 2012 at 10:44:40 am
When i am in a bin in a project and want to import rushes i used to right click, choose xcdam browser and import the selected clips in the browser straight into the bin. It now only gives me the option of xcdam transfer when i right click. I have tried all the settings but no luck. Thanks for your prompt reply! Ti
Ian Cook
on Jan 27, 2012 at 2:58:32 pm
Is it available from the FILE menu? If you try to open Browser in standalone mode from /Applications or from your dock, does it open correctly? If not, you should try reinstalling Browser. If it does, delete both the Browser and FCP preference files.
