2 EX1s with different firmware
COW Forums : Sony Cameras
Nathan Halder
on Jan 12, 2012 at 3:32:22 pm
Is there anything I should be aware of when shooting with 2 EX1s with different firmware? I would make sure both the picture profiles are the same on both. Any issues with regard to color grading? Thanks!
Marek Bilski
Re: 2 EX1s with different firmware
on Jan 13, 2012 at 10:10:43 am
What firmware versions do your cameras have?
Marek
MxM Express
Nathan Halder
on Jan 13, 2012 at 1:41:50 pm
One is 1.11. The other is 1.03.
Marek Bilski
on Jan 14, 2012 at 10:04:01 pm
OK, I can see from the firmware versions, that you shouldn't have a problem with colour having 2 different firmware versions, however, you might have problems swapping media between the cameras. You'll most likely have media errors and some other issues with 2 different older firmware versions.
You should go to the minimum 1.20v on EX1.
Regards,
Marek
MxM Express
Nathan Halder
on Jan 14, 2012 at 10:26:09 pm
Good to know Marek. Thanks for your response.
