Sandisk 64 GbSDXC card compatibility with the EX-1
COW Forums : Sony Cameras
Miguel Coyula
on Oct 13, 2011 at 3:08:18 am
I have just purchased the Sandisk 64 Gb SDXC card
http://www.bhphotovideo.com/c/product/684028-REG/SanDisk_SDSDRH_064G_A11_64...
, but I'm unable to get it work on the Ex-1. As soon as I pop it in, I get a message that reads:
"Media Needs to be Formatted"
When I try to format it;
"NG: Cannot Format
Media Error
Media (A) Needs to be restored
Any ideas? Has anybody used this card on the Ex-1?
Kevin Patrick
Re: Sandisk 64 GbSDXC card compatibility with the EX-1
on Oct 13, 2011 at 11:49:23 am
It may not be compatible with the EX1. The cards need to be fast enough to support the bit rate.
I purchased Sony's Memory Stick 32GB Pro-HG Duo HX.
They work fine, no issues.
http://www.adorama.com/SOMSHX32A.html
Miguel Coyula
on Oct 13, 2011 at 12:20:56 pm
I was told by the sales person that I should be able to do it as long as I don't overcrank.
Michael Palmer
on Oct 13, 2011 at 2:11:59 pm
CHeck to see what firmware you have on the EX1 and up grade to the latest. If you have an original EX1 they need a special firmware needs to be installed before you can load the latest.
Good Luck
Michael Palmer
Kevin Patrick
on Oct 13, 2011 at 2:35:09 pm
I forgot about that. I believe Michael is correct, you need to make sure your camera has the latest FW.
http://pro.sony.com/bbsc/ssr/micro-xdcam/resource.downloads.bbsccms-assets-...
In the release notes you they do post some limitations. You can't record slow motion with the media adapter. You need SxS cards.
Miguel Coyula
on Oct 13, 2011 at 5:30:56 pm
Thanks, it might be very well be that. However the link here is for the EX-1R does it make a difference from the EX-1?
Bob Tompkins
on Oct 14, 2011 at 2:39:12 pm
The EX1r is easier to update the firmware than the EX1. You have to be at a certain firmware level to be able to upgrade by yourself. Maybe Ian will pop on here and explain and point you to the link. It has been discussed here before.
Bob Tompkins
on Oct 14, 2011 at 2:40:34 pm
Search "EX1 firmware upgrade".
