Save Picture Profile
COW Forums : Sony Cameras
Jason Brown
on Oct 7, 2011 at 2:53:59 pm
I've looked through the manual, how can I save a picture profile from the EX3 to the SxS card to archive? I can do this on the F3, but can't seem to figure it out on the EX3.
Ian Cook
Re: Save Picture Profile
on Oct 7, 2011 at 3:23:51 pm
Others menu-->Camera Data-->Store/Recall. Only active when there's media in one of the slots. All PPs will be saved as one .suf file
Jason Brown
on Oct 7, 2011 at 7:34:28 pm
.suf file can be archived, saved, emailed...then when ready, load onto sxs card in cam...then recall?
Ian Cook
on Oct 7, 2011 at 7:37:23 pm
yes, correct
Kevin Patrick
on Oct 12, 2011 at 1:08:02 pm
I believe it has to be at the top level of the card's directory.
Also, a tip I got from watching an instructional DVD on the EX1R, is to no format the card after you've copied the the Picture Profile to the card. Formatting the card obviously deletes everything on the card. The suggestion was to use the Camera's Delete All Clips command. This will remove all the clips, but leave the Picture Profile in place. I copied my PP to all my cards.
(if this was obvious to you, or part of your workflow already, never mind)
Kevin Patrick
on Oct 12, 2011 at 1:12:58 pm
