PMW 350 Subclip Errors / Inconsistencies
COW Forums : Sony XDCAM - EX & Related
Will Torbett
on Sep 29, 2011 at 11:05:42 pm
The issue: For some reason, in two random instances, the camera is not grouping its subclips as it does by default.
Normally, every twelve and a half minutes (or four GB) the camera splits a take into subclips, which by the time we ingest the footage is one long clip (as it was shot).
Strangely, we are seeing in a few instances the footage showing up as separate clips instead. (01, 02, 03..) with no way to join them in XDCAM software. See highlighted clips below.
But it's sporadic - grouped properly in the morning, unnaturally split later, fixed again in the evening. I checked with the director/camera ops, and they didn't know anything about settings changing on the camera itself (and there's not exactly a big external toggle to bump into).
Any thoughts/suggestions? I can only assume it's a fluke, but how can we fix this, and what should we be on the lookout for while shooting?
© 2018 All Rights Reserved
