XDCAM EX1/3 vs CANON XF300/305
COW Forums : Sony XDCAM - EX & Related
Puneet Malhotra
on Sep 27, 2011 at 8:04:36 am
As tapes are being replaced by CF cards and other memory cards,and so there are variety of tapeless cameras available in market. Every model has its pros and cons.I am also looking for this format which saves a lot more time and saves one generation loss of footage.
I came across Canon XF300/305 and Sony XDCAM EX1/3 cameras.Both have some thing better than other. But what is that thing which makes any of the above model better than the best. Which of the above model is accepted in the industry....
Which has smooth workflow and accepted natively by NLEs....
I work on Premier Pro CS5
Bob Tompkins
Re: XDCAM EX1/3 vs CANON XF300/305
on Sep 27, 2011 at 12:16:59 pm
Puneet...this is not the place to pick a camera. Go to a reputable dealer and try out all of the cameras that you you are interested in. Many dealers will let you borrow...or rent at a reduced rate, the cameras you are interested in. You have to shoot with them and ingest with them and edit with them to see if they fit your needs and your workflow.
© 2018 All Rights Reserved
