Sony PMW-EX1 Firmware Update1.26 is this result normal.
Daniel Goyette
on Jun 12, 2011 at 11:40:50 pm
I everybody i have in the past update the firmware on my PMW-EX1 from 1.11 to 1.20 and now 1.26.
Everything fine exept when i go to language selection i see :English , Japaneese , Chineese , is this normal.
I got the firmware from Sony UK since i could not find-it (V1.26) on Sony Canada or Sony USA for the EX1.
Even if my primary language is French i keep all my NLE in English for simplicity and keyboard configuration.
Very happy English is there but was expecting French and Spanish , info to install was in about 6 languages.
Is the Sony download source or country made any difference on languages included in the firmware.
If it become available in Canada or USA should i download-it and apply-it , will it work if it still 1.26.
Should i forget all this and wait for a next firmware update or it is the standard international languages version.
PRODUCTION D. GOYETTE
TOURNAGE / MONTAGE VIDÉO CORPORATIF
DISTRIBUTION DVD / BLU-RAY / H.264
http://web.mac.com/edbeta
David Gallessich
Re: Sony PMW-EX1 Firmware Update1.26 is this result normal.
on Jun 16, 2011 at 8:27:26 pm
Daniel - I would check Ian's response in this thread:
http://forums.creativecow.net/readpost/142/876092
And in your case, I would probably call that phone number in my post.
(When phone menu starts getting specific, select menu item 4.)
In my case, the wait-time was reasonable and the tech was pretty helpful.
They may know what you should do if you already installed 1.26 using a bad installer.
Daniel Goyette
on Jun 17, 2011 at 6:59:46 pm
I call the number an follow your instruction about selecting item 4 in the Sony phone menu system.
I got very kind an fast information about my downloaded and installed firmware on my PMW-EX1.
It is normal to see English , Chineese , Japaneese languages selection , so all is fine an i can relax.
Thank-you and thank-you also to Ian Cook who should post about this.
Ian Cook
on Jun 17, 2011 at 8:51:28 pm
Hi Daniel-
That is correct. The language selection is normal for a US or European model.
Cheers,
Ian
Pushpanatha de Silva
on Jul 2, 2011 at 10:27:18 am
Hi Ian and all
My present f/ware version is 1.11 and would like to upgrade upto 1.26. So do I have to upgrade to 1.20 before I upgrade to 1.26 or I can upgrade straight away to 1.26 from 1.11.
Your help is much appreciated. Thanks
Pushpa
Australia
Dell Workstation T7500
Dell HD Monitors
Sony PMW EX1
Duncan Craig
on Apr 14, 2015 at 4:55:24 pm
It's an old thread I know, I know!
I normally stick to trusty 16GB cards, but recently tried some 32GB UHS1 SDHC class cards in my EX1 and got formatting errors.
I spoke to Sony and went to the following page: https://www.sony.co.uk/pro/product/broadcast-products-camcorders-xdcam/pmw-...
I was on v1.11 firmware from way back when I bought the trusty EX1. Anyway, the latest 1.3 binary on there includes a nice Mac app which seemed to perform the update to 1.3 in two stages.
Once updated the app asks to be exited. At that point I was stuck. I remove the USB cable and disconnect the power supply. I then plugged the power in again and it rebooted first time.
All working well now with a couple of different 32GB cards in the camera.
FS100, EX1, GoPro, 2x Hacks, FCPX etc
