S&Q on PMW-350
James Cordell
S&Q on PMW-350
on May 17, 2011 at 1:33:21 am
I know it's not a "EX" cam but I bet someone could help me out.
What ever I do on this camera I cannot go into the menu under "Rec Function" and turn ON Slow & Quick Motion. Doesn't matter if I have it set to 1080 (which I know won't work anyway) or any of the 720 formats. Nothing allows me to select it. It's just grayed out. At first I though it might be because we have the "economy cards". But I looked into that and these cards are faster than the "pro" versions.
There's no S&Q dial on the cam like the EX3. Unless I am totally blind. I'm at a loss. Anyone?
Ian Cook
Re: S&Q on PMW-350
on May 18, 2011 at 2:33:13 pm
Are the other settings (Cache etc) in the 'Rec Function' menu ghosted out as well? Check the setting of Assign Switch 2-- if Cache Record is assigned to this slide switch you lose the ability to select any of the Rec Function items from the camera menu.
James Cordell
Re: S&Q on PMW-350
on May 18, 2011 at 7:43:39 pm
That is exactly what the problem was. Assign switch 2 was set to Rec Cache. Thanks!!
