PMW F3 + S-Log
Jeremy Garchow
PMW F3 + S-Log
on Apr 28, 2011 at 7:19:13 pm
From what I can gather, it will only available on dual link.
Is this true?
Jeremy
Michael Palmer
Re: PMW F3 + S-Log
on Apr 28, 2011 at 7:23:24 pm
The S-Log feature will be available with the dual link firmware option. I believe it works with single link 4:2:2 also and it will require a 10 bit recorder to take advantage of S-Log.
Good Luck
Michael Palmer
Jeremy Garchow
Re: PMW F3 + S-Log
on Apr 28, 2011 at 7:26:17 pm
[Michael Palmer] "I believe it works with single link 4:2:2 also and it will require a 10 bit recorder to take advantage of S-Log."
10 bit 4:2:2 is fine and dandy. Thanks for the info. Are you sure about this, though? :)
Are you saying the S-Log and Dual Link options are bundled together, but can operate exclusively?
No S-Log available on SXS recording (just curious)?
Thanks, Michael.
Jeremy
Michael Palmer
Re: PMW F3 + S-Log
on Apr 28, 2011 at 7:33:37 pm
"Are you saying the S-Log and Dual Link options are bundled together, but can operate exclusively?"
Yes
8 bit won't capture enough data so no SxS for S-log
Good Luck
Michael Palmer
Jeremy Garchow
Re: PMW F3 + S-Log
on Apr 28, 2011 at 7:38:20 pm
[Michael Palmer] "8 bit won't capture enough data so no SxS for S-log"
Well, it's a gamma curve. I understand why this wouldn't be advisable in XDcam, but just wondering if it was possible.
Thanks much for the info, this is now more tangible.
Jeremy
Michael Palmer
Re: PMW F3 + S-Log
on Apr 28, 2011 at 8:01:29 pm
I just took delivery of my F3 and I can't wait for the upgraded firmware, and my friends from Convergent Design are working hard to make the Gemini 4:4:4 the best digital recording solution for the F3. S-Log will be a great new adventure.
Good Luck
Michael Palmer
