Crop factor using 2/3 inch lens on EX3
Mark Shepherd
on Mar 15, 2011 at 6:55:56 pm
I am experimenting using 2/3 inch lenses on a Sony EX3. What is the "crop Factor" I am using a lens with a 300mm telephoto..
Thanks in advance
Joe Tyler
Re: Crop factor using 2/3 inch lens on EX3
on Mar 18, 2011 at 7:16:18 pm
I think this is what you are looking for.
When going to a half inch sensor (ex3) from a 2/3" lens (b4, sony mount) You use a 1.3 multiplier. So your standard Canon or Fuji HD zoom lens 7.6-137mm (7.6x18) you get the equivalent of a 10.34mm x 186mm, in terms of a 35mm camera system. This would apply for putting a Fuji ACM 18 or 21 adapter on your camera and mounting a "pro video lens".
If you want the 35mm equivalent from a half inch sensor you use a 5.4 multiplier. The EX3 standard zoom lens is 5.8mm which is the equivalent of a 31mm lens (in 35mm terms)
Hope that helps
http://www.killianthered.com
DP in the Washington DC Area
EX3 Owner
Mark Shepherd
on Mar 24, 2011 at 9:14:06 pm
Thanks for the info. So if I put my 2/3 in 19x8 that would be 152mm on the TELE end, with the 2x extender that equals 304mm, times the 1.3 factor equals 395mm. So in 35mm terms, 395mm x 5.4 equals 2133mm. Wow, no wonder I was seeing fleas on Trump's hair @ 1000ft...
