importing files from ex3 camera or needed codec for quicktime
Rebecca Heininger
on Mar 10, 2011 at 9:39:32 am
Is there is a way to import files from an ex3 camera into fce?
I found the "Log and Transfer Utility for Apple FCP Version 1.2" from the Sony website, but it says you need FCP!
or can anyone help with the codec needed to view files from the ex3 in QuickTime?
any advice would be appreciated
Bek
Rafael Amador
Re: importing files from ex3 camera or needed codec for quicktime
on Mar 10, 2011 at 1:07:54 pm
[Rebecca Heininger] "I found the "Log and Transfer Utility for Apple FCP Version 1.2" from the Sony website, but it says you need FCP!"
That's right.
I think with the "Calibrated" plugins (http://www.calibratedsoftware.com) and QT Pro you would be able to export to a codec that you can edit on FCE, but no sure.
rafael
http://www.nagavideo.com
Rafael Amador
on Mar 10, 2011 at 1:36:30 pm
Hi again Rebecca,
I found that FCe is supported by the Callibrated MP4 Import plugin.
This is the version for FCE:
http://www.calibratedsoftware.com/QEXEssentials.asp
That would be enough for you to work.
rafael
