(Cinema 4D) Need assistance With Transparency render!!!!!! PLEASE
Andy Smirnov
on Mar 1, 2011 at 10:11:19 pm
Hi All,
I'm trying to render a very large scene with lots of elements.... Some of which are 1 polygon planes with image textures and alpha channel on them... like bird for example...
BUT they appear just as black planes, if I set the render for more then 20 frames of rendering... If I render the full animation 1 to 600 frames at some stage they will become black plane and start to flicker....
I've check everything.... in fact if I render frame by frame separately.. I t would probably work fine.... There are 600 frames however, so that a lot of manual render...
Another problem is that there a re black flicker and black block at the very start (Far wide angle shot of the earth and clouds,which are textures with alpha channel as well) of my animation
attaching image.
PLease, if anyone knows how to fix any of these problems post anything
Thank you
Craig Seeman
Re: (Cinema 4D) Need assistance With Transparency render!!!!!! PLEASE
on Mar 1, 2011 at 10:25:00 pm
Wrong forum. Entirely unrelated to XDCAM.
