duplicate named clips
Jay Curlee
on Feb 3, 2011 at 7:09:48 pm
Has anyone run into a situation where the EX-1 camera has created duplicate identical file names for clips which are different? What causes this issue?
Jay
Don Greening
Re: duplicate named clips
on Feb 3, 2011 at 8:07:10 pm
[Jay Curlee] "Has anyone run into a situation where the EX-1 camera has created duplicate identical file names for clips which are different?"
Yes.
[Jay Curlee] "What causes this issue?"
I'm not sure. My original EX1 did that and I know I didn't hit "RESET ALL" in the menu to make it happen. Early firmware glitch perhaps? Maybe it's time to send your camera in for the upgrade as long as you don't mind losing 2 minutes of recording time on a 16G card.
Sorry about not being more helpful.
- Don
Don Greening
Reeltime Videoworks
http://www.reeltimevideoworks.com
Duncan Craig
on Feb 22, 2011 at 9:27:24 pm
Only when the camera lost power and I had to change batteries. It went back about 5 clips and recorded them with a 02 suffix.
Or are you sure your not seeing spanning on long recordings?
You'll see a clip like ABC_1234_01 the ABC_1234_02
EX1
MBP
Short fingernails
Jay Curlee
on Feb 22, 2011 at 9:47:03 pm
Sadly I came out with identically name clips for totally different shots. I also ended up with missing footage which I believe is related to the clip naming problem.
Jay Curlee
JC Communications
Makers of Rocking the Boat: A Musical Conversation and Journey
http://www.rockingtheboatmovie.com
