Exclamation Point on clips in XDCAM Clip Browser?
Karin Hayes
on Jan 19, 2011 at 11:03:17 pm
Hi all,
I recently inserted my 16 GB SxS card into my Mac laptop. It showed up in XDCAM Clip Browser v.2.6, and I was planning to copy the clips to my hard drive (as I had just done successfully from my 32 GB card). But this time, only black thumbnails (numbered and with what seemed like the appropriate duration of clip) appeared and in the corner they had yellow exclamation points in a small triangle. Does anyone know what this is, and how I can recover the data (if it's lost) from this interview?
Thanks so much for any insight.
Karin
Craig Seeman
Re: Exclamation Point on clips in XDCAM Clip Browser?
on Jan 20, 2011 at 12:54:42 am
Generally that ! tells you the clip can't be played. If you put the card back in the camera does it give you a restore media error. If not, can you play the clips in the camera?
Karin Hayes
on Jan 20, 2011 at 1:19:31 am
Thanks. Yes, they are all visible, and they play from the camera.
Any suggestions?
Craig Seeman
on Jan 20, 2011 at 2:14:45 am
That's good news. That means the clips are OK.
I'm just confirming that you're using ClipBrowser 2.6 and XDCAM Transfer 2.12.
Karin Hayes
on Jan 22, 2011 at 7:17:47 am
Thanks. XDCAM Clip Browser 2.06 and XDCAM Transfer 2.11 After I tried it in the camera, I tried the card in the computer again, and it read and copied fine. I'm not sure what happened. Do you think it's a card on the way to going bad or just a fluke?
Thanks.
Karin Hayes
on Mar 14, 2011 at 3:11:37 am
For anyone out there with the same problem, I found the issue - it's with my XDCAM Clip Browser. If this happens (and I've checked that the file plays fine in the camera), I quit the Clip Browser, restart it, and then the thumbnails are visible, and everything works. Perhaps my Clip Browser just gets too much in it's cache or something.
Patty Kuning
on May 6, 2012 at 2:27:55 am
Thank you so much, you saved my life. I now know what "breaking into a cold sweat" really means.
