camera settings for KiPro
Ron Pestes
on Dec 15, 2010 at 6:41:35 pm
Hi Guys,
Does it matter what the frame rate settings are set in the camera when recording to a KiPro or does the camera output the same signal regardless and you just set the KiPro for what you want? Thanks for your help.
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro
Michael Palmer
Re: camera settings for KiPro
on Dec 15, 2010 at 7:57:33 pm
I know my Nano recognizes the signal it receives and I'm sure it is the same for the KiPro. If you choose 24p format then you can set the SDI output for either 60i or 24p on the EX cameras.
Good Luck
Michael Palmer
Daniel Doherty
on Dec 16, 2010 at 1:31:11 am
Yep, Michael is right. In the EX3 menu go to Genlock and choose either 60i or 24p. That will set your hdsdi out.
Ron Pestes
on Dec 16, 2010 at 1:39:50 am
OK, thanks guys.
Sony EX-3
MacBook Pro
Ron Pestes
on Dec 16, 2010 at 1:44:24 am
I was just looking at the menu and that option is greyed out. How do I turn it on?
Sony EX-3
MacBook Pro
Michael Palmer
on Dec 16, 2010 at 4:10:56 am
Try setting the camera to 24p format then look at that setting, or make sure you have a newer firmware.
Good Luck
Michael Palmer
Don Greening
on Dec 16, 2010 at 4:18:16 am
[Michael Palmer] "Try setting the camera to 24p format then look at that setting, or make sure you have a newer firmware."
Yeah, that's what you have to do so it's not grayed out: Set your recording format to 24p and then in genlock you can choose between 60i or 24psf (progressive segmented frame).
- Don
Don Greening
Reeltime Videoworks
http://www.reeltimevideoworks.com
Ron Pestes
on Dec 16, 2010 at 6:00:25 am
Got it. Why does this have anything to do with genlock? I feed the SDI signal to a Panasonic digital switcher and don't need genlock. We mix 3 cameras this way with only the SDI cable.
Sony EX-3
MacBook Pro
