Ex1 ?SD
Alan Lacey
Ex1 ?SD
on Nov 23, 2010 at 2:50:33 pm
I saw a recent posting on here implying that you could get SD-SDI out of the EX1. Is that true? I always understood the EX1 was HD only and that SD only came with the EX3.
Can someone clarify this for me please?
Alan (uk)
FlashXDR,XDcamHD,XDcamEX,D9 etc
FCS,AE,Combustion,LiquidSilver,Vegas,Edius,
G5,MBP,Vista64,XP
Ian Cook
Re: Ex1 ?SD
on Nov 23, 2010 at 3:26:36 pm
Hi Alan,
You can't do native SD recording to SxS on the EX1 but you can down convert during HD playback or E-E mode. Menu-->Video Set-->Y PB PR / SDI OUT = SD.
Best,
Ian
Alan Lacey
Re: Ex1 ?SD
on Nov 23, 2010 at 3:52:00 pm
Thanks for this Ian. You don't happen to know what the E-E quality is like do you? Good enough for decent chromakey?
Alan
G5,MBP,Vista64,XP
Ian Cook
Re: Ex1 ?SD
on Nov 23, 2010 at 3:58:56 pm
If you're taking the live output from the camera head it's actually at higher quality than during playback as you are getting an uncompressed 4:2:2 stream. If you're playing out from a card the quality is not reduced but obviously you're hitting the 35 MB codec first and coming out 4:2:0.
Ian
Alan Lacey
Re: Ex1 ?SD
on Nov 23, 2010 at 4:16:29 pm
Having just lost a old but trusted broadcast SD camera that I used for studio greenscreen this is great news.
Thanks Alan
G5,MBP,Vista64,XP
Rafael Amador
Re: Ex1 ?SD
on Nov 23, 2010 at 9:38:13 pm
Alan,
But you would get a better CK from an HD source than from an SD one.
In fact plain EX-1 footage has (more or less) the same number than Chroma samples than SD/10b Unc.
rafael
http://www.nagavideo.com
Alan Lacey
Re: Ex1 ?SD
on Nov 24, 2010 at 5:20:03 pm
Thanks for this Rafa. That's interesting info.
Alan
G5,MBP,Vista64,XP
Rafael Amador
Re: Ex1 ?SD
on Nov 25, 2010 at 6:47:06 pm
[Alan Lacey] "Thanks for this Rafa. That's interesting info."
And I forgot to add Alan, EX-1 has 4 times more Luma samples than any SD format.
To make a "White-screen" (I've never tried) should be rocking good.
Cheers,
Rafa
