PMW-EX3 Firmware 1.15 upgrade Windows Only?
Lynn Clark
on Nov 18, 2010 at 10:21:26 pm
Is the EX3 1.15 firmware upgrade now a Windows-only operation? There doesn't appear to be a Mac version of the Version Up Tool. What's up with that?
Max Reid
Re: PMW-EX3 Firmware 1.15 upgrade Windows Only?
on Nov 19, 2010 at 5:38:35 am
Latest Firmware for the EX3 is 1.5, I believe. I am told that it will now be upgradable via memory card.
Lynn Clark
on Nov 26, 2010 at 7:22:52 am
No. It's 1.15. Why speculate when it's so easy to check before you post? Besides, I didn't ask what the latest firmware version is since I already knew. I asked why the updater for the 1.15 version is Windows only.
Ian Cook
on Nov 19, 2010 at 4:02:59 pm
Hi Lyn,
This should be fixed shortly
Ian
Ian Cook
Sony Broadcast and Professional Company
Lynn Clark
on Nov 26, 2010 at 7:27:02 am
Hi Ian,
Can you define "shortly"? ;-)
Is there any reason the VersionUpTool for the 1.10 version can't be used to apply the 1.15 version? Putting on my thirty-years-of-software-engineering hat, I could speculate that the 1.10 VersionUpTool could be used, either as-is if it prompts you to select the firmware binary file to use, or by first renaming the 1.15 firmware binary file to the same name as the 1.10 firmware binary file.
Lynn (two n's)
Lynn Clark
on Nov 26, 2010 at 7:34:13 am
Hi Ian,
I see that the 1.15 firmware update .zip file has now been updated to include the Mac version.
Lynn (two n's)
