Problem Viewing XDCAM proxies
Nate Gross
on Oct 14, 2010 at 5:55:10 pm
I have been sent some XDCAM proxies that came in as .mov files. I need to know how to view or convert them to a viewable quicktime file, or something similar. When I play them in quicktime I get perfect audio, but no picture. I downloaded XDCAM transfer, but it said I was missing codecs and wouldn't even let me select the files. I don't have Final Cut so that may be part of the problem. Is there a way I can view or convert these so that I can load them into Avid.
Ian Cook
Re: Problem Viewing XDCAM proxies
on Oct 14, 2010 at 6:37:58 pm
Hi Nate,
Without FCP you won't be able to view the files in QuickTime. I would try downloading the trial version of Calibrated Software's MXF component; I believe that has support for the MPEG4 Proxy Codec.
Ian
Nate Gross
on Oct 14, 2010 at 10:37:46 pm
Thanks Ian
I'll give that a try. I do have an older version of Final Cut Express, but as I understand it, it needs to be Final Cut Pro. Is that correct?
Ian Cook
on Oct 14, 2010 at 10:43:00 pm
Hi Nate,
Yes, my guess is Express will not work with the proxies either as Apple only puts the Pro codecs in Final Cut Pro..
Ian
