XDCAM Transfer can't find footage
COW Forums : Sony XDCAM - EX & Related
Andy Taplin
on Oct 5, 2010 at 10:40:47 am
Hi All
I recently moved all my footage to a new RAID. Everything's fine except that XDCAM Transfer can no longer
find the footage - although the proxies still show as thumbnails. When you click on a clip it say's "Preview Unavailable. The original file source xxx needs to be available to see the preview movie for this clip"
I have not changed the file names or folder structures, merely moved them to a new disk. None of my other apps is having trouble finding files. There does not seem to be away to get XDCAM Transfer to re-link to the files.
Any ideas gratefully received. Thanks.
Don Greening
Re: XDCAM Transfer can't find footage
on Oct 6, 2010 at 6:46:22 pm
Try trashing the preference file for XDCAM Transfer. When you start the program again it will be with that program's default settings. See if that solves it.
- Don
Don Greening
Reeltime Videoworks
http://www.reeltimevideoworks.com
Andy Taplin
on Oct 7, 2010 at 4:00:51 pm
Thanks Don. trashed the prefs but still saying the clips are unavailable - anything else I could try?
Craig Seeman
on Oct 7, 2010 at 4:24:30 pm
Are the BPAV folders still there? Are they in Parent folders? Are you pointing to the Parent folders?
Andy Taplin
on Oct 7, 2010 at 5:28:44 pm
Hi Craig, we meet again! As you can see today is my day for posting problems to the Cow.
Yes, nothing has changed in terms of the folder structures - just that they are on a new HD.
Craig Seeman
on Oct 7, 2010 at 5:36:08 pm
But you must check on the new HD. It's possible the copy/move was bad or it's possible there's an issue in the path or even the privileges preventing access.
Andy Taplin
on Oct 8, 2010 at 11:37:16 am
Those things are all fine, I can re-add the folders, but then I loose all the previous mark in out info. It seems XDCAM Transfer lacks a relink or reload footage function - such as AFX, FCP, Media 100 has. It's annoying although not the end of the world. I think the software is a little half-baked in this respect.
