FC doesn't have 1080p
bruno perosa
on Aug 19, 2010 at 11:44:58 am
Maybe I never noticed before but FC doesn't have 1080p sequences, why?
I produce xdcam 1080p and although it's says so on the browser item properties, (both files and sequence), but in fact the sequence is 1080i and exporting it as prorez to AE is becoming interlaced (lower). WHY?
Also what is the best way to keep the 16:9 from 1080 to Pal (I'm putting the footage to a new "Pal" sequence reducing, re-framing the clips) but would like to keep the 1.78 and not 1.25 without anamorphic (getting a circular shaped object looking like a rugby ball shape)
EX3, Nikon Adaptimax with various lenses, Acuter Merlin mount, MBP17"2.93GHz, FCS2, Media100, BtcSP, DVcam
Rafael Amador
Re: FC doesn't have 1080p
on Aug 19, 2010 at 11:55:05 am
[bruno perosa] "Maybe I never noticed before but FC doesn't have 1080p sequences, why?"
Sequence presets do not makes much sense now that you can conform the sequence to the footage.
[bruno perosa] "I produce xdcam 1080p and although it's says so on the browser item properties, (both files and sequence), but in fact the sequence is 1080i and exporting it as prorez to AE is becoming interlaced (lower). WHY?"
You have done something wrong somewhere.
[bruno perosa] "Also what is the best way to keep the 16:9 from 1080 to Pal (I'm putting the footage to a new "Pal" sequence reducing, re-framing the clips) but would like to keep the 1.78 and not 1.25 without anamorphic (getting a circular shaped object looking like a rugby ball shape)"
Your PAL sequence must be Anamorphic.
cheers,
rafael
http://www.nagavideo.com
bruno perosa
on Aug 19, 2010 at 3:41:11 pm
thanks Rafael,
Clint Fleckenstein
on Aug 19, 2010 at 1:14:10 pm
Check your codec settings on export. Even if your sequence is not interlaced, the ProRes settings may default to Interlaced and you need to check them on export.
Is FCP interpreting your footage correctly? If so, dropping the first clip into a new sequence can be set in your Preferences to prompt whether you want the sequence to conform to the clip. That can be quite handy.
Cf
Rafael Amador
on Aug 19, 2010 at 2:53:38 pm
[Clint Fleckenstein] "Is FCP interpreting your footage correctly?"
Hi Clint,
I think that with XDCAM is impossible any miss interpretation.
Field order is always properly flagged.
Rafael
Greg Ondera
on Aug 19, 2010 at 1:53:55 pm
Have you downloaded the Sony XDCam drivers? There might be a more up-to-date version, but this one is at http://www.sony.ca/promedia/drivers.htm for the Mac. I know when I export it gives me the choice of 1080 30P EX in specific amongst many other codecs.
Greg Ondera
http://www.Plexus.tv
http://www.SurgeonToday.org
Greg Ondera
on Aug 19, 2010 at 1:56:34 pm
And likewise, I take a clip and drop it into a new timeline and it always asks if I want to conform the timeline to the very same standards as that first clip, and I always say yes, so I don't have to render anything.
Greg Ondera
