PMW-EX30 HD-SDI Workflow
Joao Velho
on Aug 14, 2010 at 12:14:06 am
Does anyone know if it is possible to capture XDCAM EX material from the PMW-EX30 HD-SDI output as PRORES files using the HD-SDI input of a Kona or Decklink card? In this case, does this work well?
Thanks for any help!
Michael Palmer
Re: PMW-EX30 HD-SDI Workflow
on Aug 14, 2010 at 12:33:08 am
The SDI to a Kona capturing as Pro Rez works really well. However this is a ball and chain system. For portability you should look into the Convergent Design NANO Flash
Good Luck
Michael Palmer
