SXS Card - BPAV folder empty
Losel Chuah
on Aug 12, 2010 at 9:04:06 am
Please help.
My ex1R with sxs card was working fine before.
But after using my friend's laptop to transfer file,
I suspect it was affected by virus.
After shooting, when connect through USB to computer,
the BPAV folder is empty (only 266 kb)
cannot see any file inside the computer.
But the strange thing is when the card is in the camera slot,
it can be seen and playback, just like normal.
Tried to format the card using camera and also computer.
Also tried Reset All in the camera,
But it doesn't help at all.
What should I do?
Is there any firmware to deal with it?
thanks
Losel
Bruce Rawlings
Re: SXS Card - BPAV folder empty
on Aug 12, 2010 at 12:50:11 pm
Have you checked to see if the card has become locked - little black switch on end of card.
Losel Chuah
on Aug 12, 2010 at 1:37:08 pm
Hi Bruce,
No it's not locked.
the card can be recorded and playback in the camera.
But when I connect to pc via usb,
the BPAV folder only appear as an empty folder.
strange!
Craig Seeman
on Aug 12, 2010 at 2:17:03 pm
Sorry but your workflow and goals aren't making sense to me.
[Losel Chuah] "But after using my friend's laptop to transfer file,
I suspect it was affected by virus."
So once files are copied and confirmed (using ClipBrowser with CRC ON)
You can reformat the card in camera if need be.
[Losel Chuah] "After shooting, when connect through USB to computer,
it can be seen and playback, just like normal."
Sorry but this isn't making sense. You should see ClipBrowser with CRC on and copy the cards and see what the results are.
[Losel Chuah] "Tried to format the card using camera and also computer.
But it doesn't help at all."
"doesn't help" isn't an error message or a description of a results. Format a card and it will be empty.
Losel Chuah
on Aug 13, 2010 at 3:20:06 am
Hi Craig,
Sorry for my unclear explanation. Please bare with my English.
I could see the clip now in the clip browser.
Thank very much for your help.
Previously I tried to view the clip in window explorer,
without using clip browser.
But earlier to that, i could see it in the explorer.
I think it is because i haven't install the clip browser.
I don't know why but anyway, i can use the clip browser to transfer files now, thank you.
