PMW-350 side Video Out Port?
Michael Moser
on Aug 3, 2010 at 9:32:30 pm
If I don't have the SD option on a PMW-350 what is the output of the side video out port. I'm told it is one channel of component; switchable to SD/SDI is this correct? It's obviously not the HD/SDI out.
Michael Moser
Ian Cook
Re: PMW-350 side Video Out Port?
on Aug 4, 2010 at 1:44:56 pm
Hi Michael,
The Video Out port gives you either an analog composite signal or the luminance (Y) channel of the HD signal (selectable in the Operational menu under Input and Output-->Output and i.LINK). It is intended for monitoring purposes and will output a down converted SD signal regardless of whether the SD option is installed.
Ian
Michael Moser
on Aug 4, 2010 at 2:23:44 pm
Thanks. That's what I thought.
What we discovered was that the color phase of the SD composite signal has no relationship with the color phase of the HD/SDI signal and not knowing that required a re-do of a base-line camera set up... It was a gotcha we should have anticipated, but unfortunate. I have always used the HD/SDI out for monitoring, but now I understand how it can be used as a second monitor, but not a "test out." as in the older cameras in that form-factor.
Mike
