Can't view BPAV files using xdcam viewer v2.30
Nina Galcius
on Jul 23, 2010 at 2:30:03 am
Hello,
I transfered video from SxS cards onto my PC. I was told my the camera's owner that I'd need to download and install the XDCAM viewer in order to view the files from my PC. Since I have Vista, I downloaded XDCAM viewer v2.30 but am not sure why I can't view the folders. I select 'file/open' from the viewer, then select BPAV, but then I'm presented with two options, CLPR and TAKR. I can click on one of these, then have to click past file data and eventually it says 'no items match your search.' I'm a beginner so I'm wondering if I'm skipping a basic step? How can I view these files?
FYI - I have not renamed the BPAV files, as I was instructed by the camera's owner.
Nina
Craig Seeman
Re: Can't view BPAV files using xdcam viewer v2.30
on Jul 23, 2010 at 2:09:12 pm
Actually download ClipBrowser which works with EX files. You want version 2.6. It'll also rewrap to MXF if you need to use it in an NLE that requires that (some will use the .mp4).
