Plug Output of EX-1 into a Computer Monitor
Adam Browning
on Jul 20, 2010 at 1:56:10 am
I have an EX-1 and would like to use a Computer LCD Monitor as an on-set monitor for the talent (ie. not for referencing). The monitor has HDMI, DVI-D, and VGA connections. What's the best way to get the EX-1 hooked up to it with these options?
Craig Seeman
Re: Plug Output of EX-1 into a Computer Monitor
on Jul 20, 2010 at 2:17:18 am
http://www.blackmagic-design.com/products/miniconverters/
SDI to HDMI miniconverter.
It's one of those moments you wish you had an EX1R
Bill Kunitz
on Jul 21, 2010 at 7:58:50 pm
...or you could check to see if the monitor has a component video input (component - Y/Pb/Pr, not composite). You'll get full HD straight from the camera. If it doesn't have a component in, you can get a good sized HD set that does have component input for about the same money as a converter - 'course then you won't have the conveter for other uses.
