EX1 with io HD
Dominick Pietrzak
EX1 with io HD
on Jul 9, 2010 at 5:08:19 am
Hi there! I was wondering what the advantages of using an io HD would be over just simply importing my footage directly from my EX1 via USB. I have a Mac Pro running Final Cut Studio 2. Thanks in advance :)
Michael Palmer
Re: EX1 with io HD
on Jul 9, 2010 at 6:59:14 pm
By using the EX camera to play the clips out to SDI then capturing to a computer is basically a waist of time unless you need to re-encode the native EX files to match something else or for major compositing work.
Good Luck
Michael Palmer
Dominick Pietrzak
Re: EX1 with io HD
on Jul 9, 2010 at 7:04:34 pm
So there's really no quality difference? I'm looking to get the best quality picture from my EX1 into FCS, that's why I was interested in the io HD, but if the USB works fine then there's really no point for me to get that.
Craig Seeman
Re: EX1 with io HD
on Jul 9, 2010 at 7:27:00 pm
I believe ioHD outputs Apple ProRes 4:2:2 over firewire.
EX outputs 4:2:2 Uncompressed over HD-SDI
EX codec otherwise is 4:2:0
If you were doing heavy compositing, chroma keying, color correction it might help. On the other hand I've had no problem chroma keying EX 4:2:0 shot Progressive. Keep in mind you'd be tethered to a computer and hard drives.
You'd have to have a real need to do that though. ConvergentDesign's nanoFlash could give you 4:2:2 and be a bit more portable if you need 4:2:2.
Adam Reuter
Re: EX1 with io HD
on Jul 17, 2010 at 4:55:31 am
Do not capture clips you've recorded to memory cards through HD-SDI. It may be neglibible quality loss but it'd be a waste of time/storage space. That plus the files are higher quality, again only slightly but at least storage space.
However, if you are recording a LIVE HD-SDI stream to the io HD then the benefits are 10-bit 4:2:2 and a higher bitrate with ProRes. For green screen work this would help out a lot. If I were shooting a big movie this is the route I'd go because the footage will probably be color corrected/graded heavily.
But for all else shooting to the memory cards and transferring via USB is fine.
