Los resolution shot on PDW F335L camera
Peter O'Doherty
on Jun 1, 2010 at 11:07:08 am
I filmed a Soccer match and the picture quality was terrible
Can someone please help me
Settings I used:
System: 50i
Recorded format: MPEG HD
Bit Rate HQ
I recorded for one minute and 12 seconds and the properties on the file read
Size: 54.4mb which sounds very small
Data rate: 8000kbps
Total bitrate: 8224 kbps
Frame rate: 25frames/second.
Craig Seeman
Re: Los resolution shot on PDW F335L camera
on Jun 1, 2010 at 2:58:03 pm
Check your settings. The bit rate should be around 35,000 kbps.
Are you just looking at a proxy file maybe?
Peter O'Doherty
on Jun 1, 2010 at 4:23:15 pm
The problem is I can'e seem to be able to get in the menu right.
I bought the camera as an ex-demo recently and trying to figure it out.
When I hit the menu button the only options I get are:
uoo contents
01 PAINT
02 SCENE FILE
03 FORMAT
04 SPECIAL AFFECTS
05 ASSINGABLE
06 DISC
07 OUTPUT
08 VF SETTING
09 MARKER
10 SKIN DETAIL
11 RESET
Craig Seeman
on Jun 1, 2010 at 5:04:21 pm
The manual is on Sony's site but you knew that didn't you?
http://ws.sel.sony.com/PIPWebServices/RetrievePublicAsset/StepID/SEL-asset-...
john sharaf
on Jun 1, 2010 at 5:08:20 pm
I'm not familiar with that particular camera, but Sony etiquette is to hold down rotary switch for five seconds and then turn menu toggle on to view "top" menu, then you'll have all the functions available.
JS
