Battery Light on Stand
Bill Evelyn
on May 25, 2010 at 1:25:28 am
Hey, again, everyone
My shoot is coming fast and furious and I'm using a kit that I don't usually use...so I've been pepperin' the Cow with questions. Here's another.
I'm shooting with an EX-3, and as I can't find a camera-mounted light to run off the camera's IDX Elite battery, I'm wondering if there's a light that will run off the same battery but not mounted to the camera...essentially, a lamp on a stand, powered by the battery sitting on the floor.
I used to do this in a pinch with those flat Sony BP90 batteries and Mini-Frezzi or Lowel Pro "sun guns" so the light wasn't right on the camera.
Does such an animal exist? Make and model would be great!
Thank you, as always...
Ronnie Martin
Re: Battery Light on Stand
on May 25, 2010 at 7:11:54 pm
I use a power tap from IDX that allows me to run a on camera light or one on a stand separate from the camera battery on the EX-3. I have a shoulder brace by Olof@WestsideAV.com and they included a power plug that would work for a light. I am sure you can find a power tap from IDX.... Just plug it in to the power connection on the IDX and then power you light with it. Also theere is a power tap for 12 volt lead acid batteries like the "Again& Again" 12 volt battery that will allow you to run a light.
Hope this helps
Ronnie Martin
http://www.ramtv.tv
Ronnie Martin
Kato Video Productions
http://www.dirtracingvideo.com
