EX1 and Adobe Onlocation (?)
Russell Robertson
on Mar 18, 2010 at 8:54:15 pm
Today I finally receive my Sony E1! My wife said it arrived, can’t wait to get home.
I’ve looked around a bit on the web/different forums, but can’t seem to confirm if the EX1 can be used with Adobe Onlocation. Is it possible in any/all HD modes? If not, SD modes?
Thanks in advance for any comments, suggestions.
RR
Jay Allen
Re: EX1 and Adobe Onlocation (?)
on Mar 18, 2010 at 9:03:29 pm
On location will not work w/ ex1 or ex3 in HD (HD cannot come from the firewire port)
It will only work in sd from firewire, and you have to go into the camera menu to turn it on.
Brent Critchfield
on Mar 20, 2010 at 11:20:31 pm
Actually that's not quite true. I use it all the time with my EX3 - you have to set recording modes to SP and the camera will output HDV over the firewire connection, which OnLocation supports. It makes a good field monitor in a pinch, and is a big help as a scope.
Brent
Brentwood Video Productions
Brentwood, California
Tim Kolb
on Mar 24, 2010 at 2:04:05 pm
[Brent Critchfield] "you have to set recording modes to SP and the camera will output HDV over the firewire connection"
I have an EX1 so it might be different...if you set to 'SD recording' wouldn't it be outputting DV? HDV would still be hi def...
Not a challenge, but a question...
TimK,
Director, Consultant
Kolb Productions,
Brent Critchfield
on Mar 24, 2010 at 5:17:43 pm
SP, not SD. As far as I know there's no way to get SD out of the camera except through the analog I/O. Shooting in an SP mode will set the Firewire output to HDV format. It might do the same for the HQ modes too - I've never tried it. As you said though it may be different for the EX1.
Tim Kolb
on Mar 24, 2010 at 5:20:52 pm
Ugh...I knew I need a glasses upgrade, but wow, did I scan that message too fast. Sorry...most days I can distinguish a "P" from a "D".
TimK,
Kolb Productions,
Rafael Amador
on Mar 25, 2010 at 2:20:59 am
[Brent Critchfield] "As far as I know there's no way to get SD out of the camera except through the analog I/O"
You have SD from the SDI and Components out.
rafael
http://www.nagavideo.com
Dwane Isaac
on Nov 20, 2010 at 2:21:11 pm
How do I get EX3 to work with adobe on location tried i link connection with not much success help pls
Rafael Amador
on Nov 20, 2010 at 4:25:26 pm
Read the third post.
The iLink only work in SP (HDV) mode.
rafael
