lens for ex3
eldrin flores
lens for ex3
on Mar 8, 2010 at 6:13:56 am
Im trying to find a good lens to replace the stock lens of ex3. Can the Fujinon S13x4.6RMS 1/2" CCD lens work on ex3?
Derek Reich
Re: lens for ex3
on Mar 8, 2010 at 3:58:46 pm
I'm sure you will be able to use this lens on your EX3 (with the 1/2" adapter that comes with it) but, why would you want to? The stock Fuji lens which came with the EX3 is a decent enough lens, probably about the same quality as the one you linked to (maybe even better) AND has IS. Are you looking for more telephoto?
I would look into some good 35mm Nikkor options for that. You can pick up a decent used Nikkor lens cheap and the adatpers from MTF or Adaptimax are only a couple hundred bucks.
Roddy Jamieson
Re: lens for ex3
on Mar 8, 2010 at 9:42:59 pm
Why downgrade to a Standard def lens? Although cheap the fitted lens is really excellent. Also the angle of view is much tighter on your suggested lens.
Roddy Jamieson
eldrin flores
Re: lens for ex3
on Mar 9, 2010 at 5:04:19 am
Thanks for the reply guys.
Yeah youre right, the lens from fujinon is a wrong choice.
Yes, I want a telephoto lens longer that the stock lens of ex3. I saw some lens that says 1/2" CCD, wouldnt that affect the ex3 since its CMOS? And what do they meant when they say that iris and zoom are motorized?
Don Greening
Re: lens for ex3
on Mar 9, 2010 at 5:21:44 am
[eldrin flores] " And what do they meant when they say that iris and zoom are motorized?
It means that the lens has a power zoom and power iris, meaning you don't have to twist things manually if you don't want to. I can't comment on whether you can use a lens designed for a CCD camera on a CMOS camera because I don't know. My gut feeling though, is that you can.
- Don
Steve Wargo
Re: lens for ex3
on Mar 9, 2010 at 6:08:34 am
There is no difference between a ccd and cmos, If anything, get an adapter and go to a 2/3" lens. You get better glass, probably more zoom and they're larger and let in more light. You'll be able to rent 36x or 44x sports lenses when you need to. 1/2" lenses are marginal in comparison.
Steve Wargo
Tempe, Arizona
It's a dry heat!
Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD .
Ask me how to Market Yourself using Send Out Cards
eldrin flores
Re: lens for ex3
on Mar 9, 2010 at 6:25:19 am
Thanks for all your help guys.
