Rendering to same aspect as preview
Curt Gustafsson
on Mar 2, 2010 at 3:42:14 am
I have HDV footage and Vegas Pro 9c. Vegas properties are set to 1920x1080. Render settings are set to HDV 720x480.
In the Vegas Preview window all is normal, but when rendered the height measurement is shrunk so that the top of video and immages are cut off.
How can I render HD footage so that the rendered results corresponds to what I see in Preview?
Also, after installing 9c (a couple of times) Help files (as well as context helps) are not available. How can this be fixed.
I have used Vegas Video since v. 5.0
cgustaf
Niall Harkin
Re: Rendering to same aspect as preview
on Mar 2, 2010 at 6:24:30 pm
Not used Vegas in an age, but if you want to export the same as the Vegas properties "1920x1080" which would be your preview, just select it in your export size, or do a custom export.
But the best thing to do would be to change your timeline / vegas settings to match that of your source footage and export ratio, check your cut and output at the native size.
What is the output for?
