Trouble getting clips from Sony SXS cardreader into CS4
Pushpanatha de Silva
on Mar 1, 2010 at 9:22:23 am
Hi, I am having troubles with importing clips from Sony SXS reader to my APPro CS4. I was wondering if anyone could please tell me what I should do to solve this problem.
I have transferred all clips from Sony SXS reader(INPUT Files: .XML/.MP4 format) to Output Files ((.MXF format = .MPEGHD format) using clip browser s/ware to the desktop. So it's in the harddrive. So then I tried to grab the files(with file extension .MPEGHD to the Project window of CS4. Then it says under "XML Files" that "File import failure and the file format not supported.
I hope u all will explain things like to a amature, as I am not familier with this type of file conversion. Ur help is much appreciated.
Pushpa(e-Mail: nathapushpa@gmail.com)
Craig Seeman
Re: Trouble getting clips from Sony SXS cardreader into CS4
on Mar 1, 2010 at 4:19:13 pm
Can you explain why you're using the workflow you're devised?
To the best of my knowledge, Premiere CS4 supports XDCAM EX MP4.
While this material is dated and I think some of the workflows are flat out risky it'll still give you something to go on if you're a beginner.
http://pro.sony.com/bbsc/ssr/micro-xdcamexsite/resource.demos.bbsccms-asset...
