EX1 cant focus at far distance
eldrin flores
on Feb 21, 2010 at 7:38:59 am
We have the sony ex1, and I just found out that whenever I try to zoom in to a far subject about 100 meters, I cannot focus it. i tried doing an auto-focus, still the camera cant. Is there a problem with the lens? Can I resolve this?
Rafael Amador
Re: EX1 cant focus at far distance
on Feb 21, 2010 at 7:52:55 am
The experts will forgive me if I say something wrong, but I think that at at full zoom no one camera can makes a perfect focus.
rafael
http://www.nagavideo.com
eldrin flores
on Feb 21, 2010 at 8:11:01 am
We have both ex1 and ex3, I tried a comparison with the two, focusing the same subject at a far. The ex1 seems to have problem with the lens, It didnt focus, while the ex3 focused the subject perfectly.
john sharaf
on Feb 21, 2010 at 3:02:14 pm
Sounds like a backfocus issue. If you can't fix by resetting backfocus return camera to dealer or Sony for repair.
JS
eldrin flores
on Feb 22, 2010 at 6:46:02 am
thanks for the reply, Is there a backfocus adjustment for ex1?
Don Greening
on Feb 22, 2010 at 7:28:24 am
[eldrin flores] "Is there a backfocus adjustment for ex1?"
Absolutely. You should read this first:
http://forums.creativecow.net/readpost/142/858473
and then this:
http://forums.creativecow.net/readpost/142/862962
If the flange back adjustment doesn't solve your issue you'll have to send it in to Sony or one of their authorized repair facilities.
- Don
eldrin flores
on Feb 22, 2010 at 7:42:08 am
Ok, I think something is wrong with lens itself. Thanks guys for the help! :)
Jared Meehan
on Sep 29, 2010 at 5:23:42 pm
Check the external ring which holds the elements together, if this gets loose you will have this problem. It normally will have a few dots of glue around the edge but they sometimes break loose and the ring will slowly loosen letting the elements move forward and effect focus
Michael Weisman
on Apr 10, 2012 at 7:06:01 pm
Brilliant Jared!
I was having this exact same problem today - not being able to get a sharp focus at full zoom - and sure enough, just as Jared suggested, my front element ring was about 2 turns loose! Snugged it up and all is back to normal.
Thanks Jared! You saved me a trip to $ony $ervice!
Regards,
Michael
Jared Meehan
on Apr 22, 2012 at 10:27:19 am
thats great mate!
Michiel Overeem
on Jun 9, 2013 at 7:50:45 pm
Jared thanks! fixed the problem right away! :)
Mark Levreault
on Aug 6, 2013 at 1:49:08 pm
Why didn't I think of that! Thank you so much! I was just about to send my EX1 back to Sony and I saw this. Crisis averted!
Cheers,
Mark
