Zipping a BPAV folder
Mike Drew
on Feb 19, 2010 at 12:32:44 am
Hi all, has anyone had any problems zipping a BPAV folder for transfer via FTP? I will get the cards a day or 2 later but the cut has to start ASAP after the shoot in another city.
Thanks in advance.
Mike
Mike Drew
Avid AE Shake Flame
Craig Seeman
Re: Zipping a BPAV folder
on Feb 19, 2010 at 12:49:26 am
Just to be on the safe side I'd but the BPAV in a parent folder with a unique name and zip that.
I can see a bit of a mess happening if you unzip multiple BPAV folders all named BPAV.zip
You're going to need some heavy duty bandwidth speeds to move these files around.
You might need to check both the sender and receiver speed to whatever distant server to see what speed you can expect. Your local speed may even be very fast but it's the speed to the area you're sending to that's important.
http://www.speedtest.net/index.php
Mike Drew
on Feb 19, 2010 at 2:25:54 am
Thanks Craig, I'm not worried about bandwidth (dedicated fibre between studios) just file corruption.
Any thoughts?
Mike
Mike Drew
Avid AE Shake Flame
