1080p or 720p video format for a PAL DVD project?
John Winski
on Feb 1, 2010 at 2:17:53 pm
Hi, I am working on a project for a charity, which is helping build schools and helping to train teachers in Cambodia. I am shooting footage on an EX1R. The footage will be used for DVD training videos to be used in Cambodia (PAL, 230v 50hz). I'd like the option also to use some of the footage for public service announcements on TV in Singapore or in movie theaters (ads prior to beginning of movie). I am editing in FCP6.
Am I best off shooting in 1080p25, or should I shoot in 720p or some other format? Any other important settings to consider?
Thanks in advance for your help!
Alister Chapman
Re: 1080p or 720p video format for a PAL DVD project?
on Feb 1, 2010 at 6:20:44 pm
It depends on where your priorities are. If the primary use is SD DVD then I would shoot 720P as this tends to down convert with less aliasing. If you want the smooth motion look of 50i video then shoot 720P50. If you want a filmic look then 720P25. However if your primary concern is the quality on a big screen in HD then shoot 1080P25.
It also helps when down converting to soften the image just a tiny bit. Turning down the detail level in the picture profiles to -10 greatly reduces aliasing in both HD and SD with only a minimal effect on the HD images apparent sharpness.
Alister Chapman
http://www.xdcam-user.com
Michael Slowe
on Feb 1, 2010 at 6:27:02 pm
Alister, you don't think that shooting 1080i is a good idea at all?
Michael Slowe
Alister Chapman
on Feb 1, 2010 at 6:40:39 pm
Not for general software down conversion to SD. As the math doesn't work well with odd numbers of lines in each field being discarded it can lead to nasty jaggies. Some software converters will make a total hash of down converting fields. I find that 720P50 is the most reliable way to get good 50i SD.
When down converting to SD having too much detail can be your enemy. The more detail you start off with the bigger the problem becomes. In HD if you have a gentle transition from light to dark over 4 pixels when you down convert that to SD, if your not careful you end up with an instant transition from light to dark over just 2 pixels. If there is any movement this then becomes pixels flashing on and off, it doesn't look good and leads to jaggies and aliasing etc. A lot depends on the way the downconversion is done and whether it incorporates anti-aliasing or predictive/adaptive scaling.
Alister Chapman
Rafael Amador
on Feb 2, 2010 at 5:13:16 am
I agree with Alister.
Normally i end up in DVD and i shoot 720p25.
In theory is the flavor that allow more quality (data per pixel).
Soot interlaced only if so have been required.
rafael
http://www.nagavideo.com
John Winski
on Feb 2, 2010 at 6:02:38 am
Thank you both very much for the advice! I'll go with 720p25!
Michael Slowe
on Feb 2, 2010 at 10:38:17 am
So, Alister and Rafael, if one is intending to end up with SD DVD's is there any point in shooting HD at all? I've been finding though that since I started shooting HD my down converted SD pictures are better. I either convert within Media 100 or, more often now, with the greatly improved BitVice. Although my material is interlaced the BitVice down convert must have the anti aliasing that Alister refers to because I now have very little trouble, used to though with previous down converts.
Michael Slowe
James Hilton
on Feb 2, 2010 at 12:53:25 pm
I have done it both ways, and unless you want some extra work, go with 720p50.
If you use 1080i25 you are best off using motion estimation to recreate 1080p50 then downcovert that to SD, it works well.
If you have 720p50 just convert to PAL SD 25i.
What you use to resize makes a big difference, I have actually found an AviSynth script with lanczos resize working on an uncompressed avi can often result in less aliasing than getting FCP or Premiere to do the same resizing for you.....it is a lengthy pc only option if you are having trouble with aliasing in your video though.
In my experience results usually look better if you resize the output from a good HD camera & codec than shooting with a good SD camera form the start, technology has moved on and downsized picture quality from your EX1R will potentially beet the majority of SD cameras out there.
Rafael Amador
on Feb 2, 2010 at 4:36:12 pm
Hi Michael,
We start always with the 1920 x 1080 pixels of the CMOS, and whatever the workflow to SD, you have to downscale somewhere. and you know downscale is a critic operation.
Nowhere else (software, hardware solution, Teranex..) you will get the downsizing that you get in camera: at 12 or 14b and from a pristine-untouched signal right from the CMOS.
About quality, the best option would be shooting directly in SD, of course you would lose the possibilities of playing with a bigger picture.
720p is a middle point. You let the half of the downscale, but keep some room to re-frame, pan, zoom, etc. And as I said, 720p25, is the setting that offers more info/pixel.
720p50 have no much meaning for me: You end up trowing away half of the picture. Only if you want to make an slow motion without losing the audio.
rafael
Alister Chapman
on Feb 2, 2010 at 7:41:17 pm
My experience is that a high end SD camera such as a Digibeta etc can produce an image equal to a very well downconverted HD camera. The SD camera is optimised for SD, it has the appropriate optical low pass filtering for SD and the noise can be lower due to the larger pixels. However well done HD downconverted to SD should look very good.
The advantage to shooting HD is that you have so much more real estate to work with. This gives you the ability to crop in to the image or re-frame, it also helps future proof your rushes. It's particularly useful for chroma key work where any small keying errors are less noticeable as they tend to be smaller. I shoot pretty much everything HD these days, downconverting when I need SD.
Alister Chapman
John Winski
on Feb 2, 2010 at 11:04:23 pm
Hi Alister, I sent a note to Sony to ask them about the formats and to better understand the new format naming convention used in the ex1r. Here is their response: Unlike HDV and similar formats, the EX1R is actually a progressive imager and recording, you will not have any more aliasing in 1080 than you would have in 720. Shooting in 1080 will give you more temporal resolution and depth of modulation, which will actually yield a better down conversion.
"Unlike HDV and similar formats, the EX1R is actually a progressive imager and recording, you will not have any more aliasing in 1080 than you would have in 720. Shooting in 1080 will give you more temporal resolution and depth of modulation, which will actually yield a better down conversion. New to the EX1R are formats that were not previously available on the other EX cameras. This required a change in the naming of the formats. For example, in HQ mode, you can shoot in 1920 x 1080 or in 1440 x 1080 resolutions in 60i, 30P, and 24P. To differentiate these modes, they decided to use the horizontal resolution for naming instead of the vertical resolution as other cameras do. So now you see HQ 1920/60i and HQ 1440/60i. When you see a 1280/50i, that indicates you are recording at 1280 x 720 @ 50i."
Would you agree on the aliasing issue?
Alister Chapman
on Feb 3, 2010 at 9:31:57 am
Not entirely, they are only referring to 1080i v 720P and are not considering the use of 720P50(60).
The downconversion from 1080 to 720 in the EX is very good and must incorporate anti-aliasing as the aliasing in the 720P images is minimal. When downconverting either 1080 or 720P to SD you must include further anti-aliasing and this is where you enter a grey area. If you are dealing with 1080i it is very difficult to accurately anti-alias as you are working with fields where on a line by line basis there may be temporal differences and if you try to anti-alias just a single field, then you are working with in effect an image where half the data has been discarded, this in itself can lead to bad aliasing. Now it is possible to get good quality downconverts from 1080i, BUT you need a very good conversion process and you need to take a lot of care. 1080P is much easier to deal with as you don't have the field issues, but your maximum temporal resolution (movement) is either 25fps or 30fps and for sports or fast action this may not be appropriate.
The compromise therefore is to shoot 720P50(60). Most of the required antialiasing required to get from the 1080 resolution of the imagers will have already been done in camera. There are no issues with field aliasing or field order errors and you have a temporal resolution of 50/60 fps. Even a downconversion with only poor anti-aliasing will look acceptable and you are likely to get more consistent results.
So while in theory 1080 should give a better image and with great care and the right software can do this. The reality is that 720P at 25/30fps or 50/60fps depending on the temporal motion you want is much easier to deal with and the difference in the final SD image between one acquired at 1080 and 720 is going to be so small that I very much doubt that anyone would ever see it.
Alister Chapman
John Winski
on Feb 3, 2010 at 12:54:51 pm
Thank you! 720p50 it is! Crew just arrived in Cambodia--thanks so much for your help!
